TwinTurbo.NET: Nissan 300ZX forum - Re: Suspected blown head gaskets. Please help.
Subject Re: Suspected blown head gaskets. Please help.
Posted by txq45 on April 25, 2008 at 2:12 PM
  This message has been viewed 125 times.
In Reply To Suspected blown head gaskets. Please help. posted by OpticalZ on April 25, 2008 at 12:02 PM
Message How did the mechanic find out there was no compression>
Educated guess, actually used guages and stuff like that>
Yes,,you can take the engine out with out a lift but you'll need a engine host.
Check compression on all cylinders and do a leak down test if possible it'll tell you where the leak is ,, compression rings air goes into crankcase, out the exhaust,,exhaust valves, out the intake ,, intake valves,,, out into the coolant ,, bubbles in radiator..
But,, from all the driving after it was hot you can have alot of things wrong with it.
